[Qgis-user] wg84 projection problem
Alex Mandel tech_dev at wildintellect.com
Thu Oct 29 02:01:38 PDT 2009
Were you using GDAL Translate on the command line(if so what was the
command you used?) or with the new GDAL Tools python plugin in QGIS? Did
it give you an error or just fail to show up. I tend to start by
importing the Raster 1st to make sure it's in the projection I want it
in before overlaying Vectors.
Alex
Markus Nater wrote:
> thank you Alex
> and thank you Otto
> when I do take a projected coord system (set to wgs84 zone 47N), the
> measurements are correct.
> but then arises a new problem, as I have a raster shaded relief as
> geotiff overlayed, that is referenced in wgs84. projection on the fly
> makes this raster invisible... strangely! and I havent found out how to
> work around this yet. i cant work out to reproject this raster either,
> somehow nothing ever happens using the gdal raster translation.
> any ideas how to solve this little problem? :-)
> cheers
> markus
> Alex Mandel schrieb:
>> Markus Nater wrote:
>>> Hi List
>>> I have some polygons in qgis with wgs84 projection. But when I try to
>>> measure distance in meters, it gives me back 1cm for 0.1 degrees, which
>>> is of course totally wrong.
>>> how can I fix this, so I will have the correct measurements in meters?
>>> cheers
>>> markus
>> Enable projection on the fly, and pick a projected coordinate system.
>> Technically in WGS84 the best you could get is great circle distances,
>> and I'm not sure the measure tool does this yet. So you need to be in a
>> projection that flattens the map evenly for distance measurement.
>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
