[Qgis-user] Trying to get the wktraster plugin to work
MaurĂcio de Paulo
mauricio.dev at gmail.com
Wed Dec 1 10:19:22 PST 2010
Hi Andreas,
As you were able to load the raster metadata i'm assuming you installed the
wktraster sql on the database.
I've never tested myself on postgresql 9.0.
Do you have a postgresql 8.4 instance to test too? Just to be sure if it's a
gdal incompatibility with 9.0.
Thanks for the information, I'm repassing to Jorge (GDAL's developper).
Best regards,
Mauricio de Paulo
> I am trying to get the wktraster plugin to work.
> The initial connection to the db is fine. It lists all my raster datasets
> I have in the db.
> After selecting a raster (and adding the schema-name in front of the
> table-name) I hit ok and after entering the password again, I get the
> following error message:
> Could not load PG: dbname=uster host=localhost user=an password=xxx
> port=5432 table=dtm.dtmav mode=1
> In the console that started QGIS I get a warning:
> Warning: This version of PostgreSQL is not supported and may not work.
> ERROR 1: Error browsing database for PostGIS Raster properties
> Here is my Postgres/Postgis version string:
> "PostgreSQL 9.0.1 on x86_64-unknown-linux-gnu, compiled by GCC gcc (Ubuntu
> 4.4.3-4ubuntu5) 4.4.3, 64-bit"
> "POSTGIS="1.5.2" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
> 2009" LIBXML="2.7.6" USE_STATS"
> Do you have any idea what may be wrong here? Is PostgreSQL 9.0 not
> supported? It works fine with my other QGIS projects ...
> Thanks,
> Andreas
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
Mauricio de Paulo
Engenheiro Cartografo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101201/e174d49a/attachment.html>
