[Qgis-user] QGIS 1.6 Custom Projection - Example. ESPG : 54004
    Noli Sicad
    nsicad at gmail.com
    Fri Dec  3 03:27:39 PST 2010
Hi Giovanni,
I am using Qgis 1.6.0.1 ubuntu. It seems that qgis is not saving it.
There is no entry in "User Defined Coordinate System".
Thanks.
Noli
On 12/3/10, Giovanni Manghi <giovanni.manghi at gmail.com> wrote:
> Hi,
> On Fri, 2010-12-03 at 22:09 +1100, Noli Sicad wrote:
>> Giovanni Thanks.
>> I gave a name and saved it.  But I don't know to use it
> when you open the dialog in QGIS that allow you to choose a coordinate
> system you see a long list and you have a filter to help find the one
> you need.
> The list is exoloded by default but it is grouped in three categories:
> "geographic", "projected" and "custom". Your new coor. system is in the
> latter category.
> You can also search for it (using part of the name you gave it) using
> the filter.
> cheers
> -- Giovanni --
