[Qgis-user] crash import xy file
Chris Crook
ccrook at linz.govt.nz
Thu Dec 9 09:50:23 PST 2010
Hi Eugenio
Could you supply an example text file that causes this and the settings you used to import.
I recently provided a patch to the delimited text plugin to read wkt columns, so problem may be related to this?
Cheers
Chris
________________________________________
Sent: 09 December 2010 22:08
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] crash import xy file
Hi to all,
i'm tring to import a xy txt file, but qgis crashs with this message:
Fatal: ASSERT failure in QList<T>::operator[]: "index out of range", file /usr/include/qt4/QtCore/qlist.h, line 447
Abortito
I'm on debian squeeze OS with qgis svn compiled version 14875 (1.7-trunk).
Which is the problem?
Thanks
E.
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
