[Qgis-user] AutoGCP Plugin
Ivan Mincik
ivan.mincik at gmail.com
Thu Dec 9 13:51:57 PST 2010
On Thu, Dec 9, 2010 at 7:43 PM, Gary Smith <gary.smith.rsa at gmail.com> wrote:
> All,
> Can someone assist with this problem please.
> I am running Debian Linux.
> I have built QGIS from source - r14877M
> When I install the AutoGCP plugin ver 0.5 the plugin manager indicates that
> ver 0.4 is installed.
> I can remove the plugin but if I re-install it ver 0.4 appears to be
> installed again.
> The upgrade option appears daily i.e. ver 0.4 -> ver 0.5.
> The ver 0.4 does not work at all. That is, none of the menu option work at
> all.
> How can I remove all trace of ver 0.4 so as to start afresh?
> Or are there any other suggestions?
You can manually delete plugin from '.qgis/python/plugins/' directory.
Ivan
