[Qgis-user] Fix polygon that is not closed?
Zoran Jankovic zoran.jankovic at zisis.hr
Fri Dec 17 00:52:51 PST 2010
Yes, and QGIS displays the shapefile with no problem, and I was unable to
visually find where is this topological error... But, nevertheless, PostGIS
refuses to import it, and geometry validity check says its not closed :-(...
I have a couple more polygons that are, supposedly, self intersecting, but
could not find those intersections visually. All of the polygons were
created using Dxf2SHP plugin.
Zoran Jankovic
ZIS-Izrada softvera i savjetovanje / ZIS - Software Development and
Consulting
http://www.zisis.hr
M: 00 385 98 682 902
T:  00 385 44 683 374
A. Senoe 4
44320 Kutina
Croatia
On Fri, Dec 17, 2010 at 5:53 AM, Brad Nesom <gisbradokla at live.com> wrote:
> arcmap found no problem with that file usig geometry check.
> On Thu, Dec 16, 2010 at 2:36 PM, Zoran Jankovic <zoran.jankovic at zisis.hr>wrote:
>> Hi list,
>> I have isolated a polygon that is supposedly not closed (fTools - check
>> validity), and PostGIS refuses to load it because of it. I was playing with
>> node tool, but I do not see a way to detect were this polygon is not closed?
>> It looks perfectly normal to me... (attached).
>> How can I fix this, besides using FME (kind of out of my league,
>> budget-wise :-)).
>> Zoran Jankovic
>> Consulting
>> http://www.zisis.hr
>> A. Senoe 4
>> 44320 Kutina
>> Croatia
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101217/1a6b62f4/attachment.html>
