[Qgis-user] Fwd: Import _and_ process DXF?
Zoran Jankovic
zoran.jankovic at zisis.hr
Wed Feb 3 04:04:16 PST 2010
On Wed, Feb 3, 2010 at 11:47 AM, Lionel Roubeyrie <lroubeyrie at limair.asso.fr
> wrote:
> Hi Zoran,
> there's a dxf2shp plugin working perfectly on your file.
> Cordialy
Yes, it creates shapefile with polylines, and even a separate shapefile with
text (if you check the "Export text labels". But, it does not (can not?)
create _polygon_ shapefile, nor there is a way to associate parcel number to
the parcel shape... That was the question ;-).
As for the new GDAL/OGR: Osgeo4win installer says the highest supported
version is 1.5.4-4 (Exp setting).
> Le 03/02/2010 11:34, Zoran Jankovic a écrit :
>> I'm resending, the first one seemed to bounce as too big...
>> ---------- Forwarded message ----------
>> From: Zoran Jankovic<zoran.jankovic at zisis.hr>
>> Date: Wed, Feb 3, 2010 at 9:27 AM
>> Subject: Import _and_ process DXF?
>> To: qgis-user<qgis-user at lists.osgeo.org>
>> Hi,
>> I have cadastrial data like the sample in the attachment. It's layered
>> DXF,
>> with parcel numbers as block references in the layer "1_kc_broj", and the
>> "main" layer of cadastrial parcel boundaries is "1_kc_medja".
>> I would like to import this DXF into SHP (or directly to PostGIS?) _with
>> the
>> attribute "parcel_number" as well.
>> Over the years I have used trial versions of FME, and this can be done, of
>> course, using this - let's say it gently - not so cheap commercial
>> application. Could it be done in QGIS (some plugins I am not aware of)?
>> Best regards,
>> Zoran Jankovic
>> ZIS-Izrada softvera i savjetovanje / ZIS - Software Development and
>> Consulting
>> http://www.zisis.hr
>> M: 00 385 98 682 902
>> T: 00 385 44 683 374
>> A. Senoe 4
>> 44320 Kutina
>> Croatia
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Lionel Roubeyrie - lroubeyrie at limair.asso.fr
> Chargé d'études
> LIMAIR - la Surveillance de l'Air en Limousin
> http://www.limair.asso.fr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100203/3205881e/attachment.html>
