[Qgis-user] Hello
Pierre Chevalier Géologue
pierrechevaliergeol at free.fr
Wed Jan 13 04:54:20 PST 2010
All right, I haven't tried it. Actually, I don't use the print
composer, I usually export maps from the mapper, which works fine for
me. I try the print composer right now. Oh, it has changed much. Let's
see...
But I still think that a graticule displayed on the mapper would be very
helpful, when you work on maps.
A+
Pierre
PS: sorry, I first replied out of the list.
Andreas Neumann claviota:
> regarding the coordinate grid:
> this is now in the print composer (Version 1.4 and above). No more
> complicated workarounds or separate plugins ... This new feature is
> available when a map item is selected and active in the print composer.
> Activate the grid with the checkbox and make your settings. I am sure that
> there are special cases not handled in the print composer, like grid in a
> different coordinate system than your data (eg. data in UTM and grid in
> degrees (lat/lon)). But most general cases should be possible now.
> Andreas
> On Wed, January 13, 2010 9:29 am, Pierre Chevalier Géologue wrote:
>> Good morning,
>> Brett Adams claviota:
>>> Hi Pierre,
>>> I'm a geophysicist in Australia, working primarily in Nickel and IOCG.
>>> Just started my own consultantsy this year and started with Qgis last
>>> week. My requirements of Qgis sound very similar to yours.
>> Certainly. You geophysicists like bright colours, and we geologists
>> have more dull colours, but after all, we are dealing with the same
>> thing: rocks, displayed on maps! ;)
>> So I believe we should have similar requirements!
>>> How are you getting a coordinate grid around your maps?
>> Not easily. Usually, I generate several graticules using the
>> appropriate plugin, which creates a shapefile for each graticule. I
>> have to manually change the srid, and then I overlay all my graticules,
>> using different transparencies, to get a neat visual effect. I also
>> play with labels, according to map scale and the step of graticule.
>>> I'm hoping you have a better (faster) system than me.
>> I'm afraid not... ;(
>>> My process works but is a bit of stuffing about. I generate a vector
>>> grid, edit the DBF file, reimport the DBF then get the labels organised.
>> All right: then, you end up with points with a little cross symbol, if I
>> understand well, with labels around them.
>> I believe this is a feature that would be needed by many of us, qgis
>> users. I had the plan to try to write a plugin to do a neat graticule,
>> generated every time the map is changed, with coordinates every 1km, or
>> 100m, or 1000km, depending on the zoom, or 1°, or 30", etc. depending on
>> the srid (which may be different from the map). But no time...
>> So many software packages already do this neatly, so I guess it should
>> not be too difficult to adapt their code. I'm thinking of viking, for
>> instance.
>> A+
>> Pierre
>> ____________________________________________________________________________
>> Pierre Chevalier Géologue EI
>> Mesté Duran
>> 32100 Condom
>> Tél+fax : 09 75 27 45 62
>> 05 62 28 06 83
>> 06 37 80 33 64
>> Émail : pierrechevaliergeolCHEZfree.fr
>> icq# : 10432285
>> skype : pierre.chevalier1967
>> http://pierremariechevalier.free.fr/pierre_chevalier_geologue
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-use
Mesté Duran
32100 Condom
05 62 28 06 83
06 37 80 33 64
icq# : 10432285
