[Qgis-user] render GPS tracks as points instead of lines
maning sambale emmanuel.sambale at gmail.com
Fri Jan 15 21:57:06 PST 2010
Found a way by simply converting them to wpt in gpsbabel.
gpsbabel -i gpx -f osm_trackslogs.gpx -x transform,wpt=trk -o gpx -F
osm_trackslogs_wpt.gpx
On Sat, Jan 16, 2010 at 11:54 AM, Noli Sicad <nsicad at gmail.com> wrote:
> Maning
> What is format file of "traces from OSM"?
> Noli
> On 1/16/10, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi Maning,
>> On 1/16/10, maning sambale <emmanuel.sambale at gmail.com> wrote:
>>> Possible?  I downloaded traces from OSM as a reference points for
>>> rectification.  Some traces have no timestamp so the tracks were a
>>> jumble of lines in QGIS.
>>> I want it displayed simply as points.  Is there a way to do it other
>>> than converting the trackpoints to waypoints?
>> Try this, save it as shapefile in QGIS and use OGR converter (QGIS
>> plugin) - shapefile to gpx. Hope get  waypoints -points.
>> HTH,
>> Regards, Noli
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
