[Qgis-user] [QGIS-LIST] Contour plugin install under OSGEO4W
Lionel Roubeyrie
lroubeyrie at limair.asso.fr
Mon Jan 18 02:50:07 PST 2010
Benoit,
I never used OSGEO4W, I only work on Linux workstations. Like says here
http://trac.osgeo.org/osgeo4w/wiki/pkg-python, you need to install modules under
the osgeo4w python directory, then effectively the .exe file provided by shapely
won't work, sorry for the mistake :( Maybe playing with ctypes under the osgeo4w
installation, but I don't know how to...
With GRASS yes you have some contours possiblities.
Le 18/01/2010 10:50, Benoit de Cabissole a écrit :
> Hi Lionel,
> Thanks for your reply.
>> Lionel Roubeyrie wrote:
>> Hi Benoit,
>> Have you tried to install shapely windows .exe from the pypi repository?
>> http://pypi.python.org/pypi/Shapely
> Yes, I've tried. I had Python 2.5 installed as a standalone app with the
> shapely .exe installed in its tree. I've removed the standalone python and
> all its modules and now the shapely .exe cannot install because there is no
> trace of python in the Windows registry anymore! (The windows installer for
> python modules seems to look up in the registry to locate the path(s) of the
> installed python(s), but OSGEO4W does not show itself in the registry and
> I've been unable to find any trick, while running shapely .exe, to go pass
> the install screen where you have to select the python tree to install to.)
> As I understand it, the OSGEO4W system is a UNIX-like environment (e.g. à la
> 'msys') and I was thinking that a UNIX-like install is the only way to
> install python modules in OSGEO4W?!?
> Note that the contour plugin works fine with the standalone versions of QGIS
> (1.4& 1.3) and the standalone version of python. It's only in the OSGEO4W
> environment that the pluging fails to install because shapely is not
> packaged with OSGEO4W. Question is: can shapely be included in the OSGEO4W
> system?
> Under OSGEO4W, the alternative would be to use GRASS plugin to do the
> contouring?
> Benoit
>> Le 16/01/2010 11:47, Benoit Mweb a écrit :
>>> Hi List,
>>> I'm trying to install the Contour python plugin under QGIS 1.4 and
>>> OSGEO4W on WinXP machine. Problem is that the plugin requires Shapely to
>>> be installed in python OSGEO4W. But I have no way to install Shapely: it
>>> depends on CTypes that does not seem to be implemented in Python OSGEO4W
>>> (when installing Shapely with "Python setup install" I've got an error
>>> saying CTypes is needed). And I cannot install CTypes because there is
>>> no compiler in the msys install.
>>> Does anybody know how to install the Contour plugin under
>> OSGEO4W? Thanks.
>>> Benoit
>>> WinXP - QGIS 1.4 - OSGEO4W
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Lionel Roubeyrie - lroubeyrie at limair.asso.fr
>> Chargé d'études
>> LIMAIR - la Surveillance de l'Air en Limousin
>> http://www.limair.asso.fr
Chargé d'études
