[Fwd: Re: [Qgis-user] How to create a slope analysis?]
    Micha Silver
    micha at arava.co.il
    Sat Jan 23 07:35:18 PST 2010
I can verify the problem outlined below with the Contours plugin. On
Windows, the Shapely python library will only install under a regular
(i.e. registered in the Win registry) python installation. But the
Contours plugin only searches in the QGIS python installation. So
shapely.geometry is never found.
Any ideas how to fix this are welcome. For example, can Shapely be added
to the OSGeo4W install like matlibplot is?
Regards,
Micha
-------- Original Message --------
For the time being I'm concentrating on WIN QGIS 1.4 since local
authorities we want to promote QGIS generally use Windows platform:
Update:
1. WIN QGIS 1.4 successfully installed;
2. OSGeog4W successfully installed;
3. Contour plugin won't install, it required matplotlib-0.99.1
4. Got matplotlib-0.99.1 from Sourgeforge as advised by Lionel Roubeyrie
but won't install, it required at least Python 2.2
5. Python 2.6.4 successfully installed
6. matplotlib successfully installed until "finish"
7. Contour plugin STILL won't install, it STILL says require matplotlib
I'm running round in circles.
Other than that the Survey Dept gave DEM contour plans in shape files
with x, y and z coordinates so I can now use them for R&D now am hoping
to get the Contour plugin active.
Pls advise. Thanks
Abbas Abdul Wahab
http:badaveil.multiply.com <http://badaveil.multiply.com>
On 20 January 2010 15:09, Micha Silver <micha at arava.co.il
<mailto:micha at arava.co.il>> wrote:
    On 01/20/2010 06:23 AM, deepika acharya wrote:
        Hello
        How can use grass tool in QGIS ?
    If you have installed the GRASS plugin, then make sure the plugin is
    active (in the Plugins->Manager) then open a Location/Mapset and off
    you go...
    The explanations in the User's manual are quite good:
    http://www.qgis.org/en/documentation/manuals.html
        Thanks !
        Regard
        Deepika
        This mail was received via Mail-SeCure System.
    Micha Silver
    http://www.surfaces.co.il/
    Arava Development Co.  +972-52-3665918
