[Qgis-user] Othos and QGIS forum
David Fawcett david.fawcett at gmail.com
Fri Jan 29 19:24:31 PST 2010
Tom,
Most OS GIS libraries can't read ESRI's proprietary .rrd and .aux
files.  If your image is a georeferenced .tif, try the .tif file in a
directory by itself.
David
On Jan 29, 2010, at 7:54 PM, Tom Mort <tom_mort at sbcglobal.net> wrote:
> I am new to Quantum GIS and have a couple questions.  I have some
> layers from an Arcview GIS that I can use, however, I am having
> trouble with an ortho layer.
> For the ortho layer I have 5 files.  They are .img, .img.xml,
> tif, .aux and .rrd.
> The layer shows up on the left part of the screen and I can see its
> properties and so forth, however, I can't view the ortho image.
> Transparency is set to none and I have tried with only the ortho
> layer added as well as along with several other layers with the
> ortho either on top of the list or on the bottom.
> I can't see the image in any case.  In the case where the ortho is
> the only layer turned on if I have transparency set to none
> everything is black, if at 50% everything is grey, 0% white.
> Anyone have any idea what I am doing wrong?
> Also, I tried to register for the qgis forum several months ago and
> could never login.  If I entered my username (email) and password it
> said it hadn't been activated but I never received an activation
> email.  I contacted someone and they said their server was having
> problems.  I tried again a few days later with another email with
> the same results.  My issue was that qgis wouldn't install with
> Fedora 11 so I dropped the matter.  Since that time I've upgraded to
> Fedora 12 and there is a different qgis package for it which does
> install, however, I still can't login to the forum and I can't use
> either of my emails because they are both associated with
> (inactivated) accounts.
> Help please
> Qgis-user mailing list
