[Qgis-user] Othos and QGIS forum
    Micha Silver
    micha at arava.co.il
    Sat Jan 30 03:25:42 PST 2010
Tom Mort wrote:
> I am new to Quantum GIS and have a couple questions.  I have some
> layers from an Arcview GIS that I can use, however, I am having
> trouble with an ortho layer.
> For the ortho layer I have 5 files.  They are .img, .img.xml, tif,
> .aux and .rrd.
> The layer shows up on the left part of the screen and I can see its
> properties and so forth, however, I can't view the ortho image.
> Transparency is set to none and I have tried with only the ortho layer
> added as well as along with several other layers with the ortho either
> on top of the list or on the bottom.
Maybe it's just a matter of choosing a color ramp?
In the properties window for the *.tif raster, in the General section,
choose "Pseudo Colors" instead of "Gray scale". If that displays the
tiff with a selection of colors, then you'll want to switch to "Color
map, and then go over to the Colormap section and set up how many
classifications, and what colors for each...
> I can't see the image in any case.  In the case where the ortho is the
> only layer turned on if I have transparency set to none everything is
> black, if at 50% everything is grey, 0% white.
> Anyone have any idea what I am doing wrong?
> Also, I tried to register for the qgis forum several months ago and
> could never login.  If I entered my username (email) and password it
> said it hadn't been activated but I never received an activation
> email.  I contacted someone and they said their server was having
> problems.  I tried again a few days later with another email with the
> same results.  My issue was that qgis wouldn't install with Fedora 11
> so I dropped the matter.  Since that time I've upgraded to Fedora 12
> and there is a different qgis package for it which does install,
> however, I still can't login to the forum and I can't use either of my
> emails because they are both associated with (inactivated) accounts.
> Help please
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
