[Qgis-user] Serious bug returns to Qgis revision 13878
William Kyngesburye
woklist at kyngchaos.com
Mon Jul 5 10:51:53 PDT 2010
I poked around a bit - looks like only 1 change between r13519 and r13597: r13570, reenabling raster legend icons. I reverted this change (local copy) and the project again loads fast.
Nothing else I can do, hopefully Marco can figure something out. Maybe cache the icons in the project, or an option to turn raster legend icons off, or something else to speed up the process?
On Jul 5, 2010, at 10:35 AM, Greg Coats wrote:
> After weeks of direct (non-public) discussions, on Jan 18, 2010, at 12:50 AM, I first publicly posted the Qgis slow start up issue under Subject: Qgis slow start up, and noted that a small 14 MB sample Qgis project can be download from http://homepage.mac.com/gregcoats/jp2/images/dcua_reduce4_03.zip
> On Jan 22, 2010, at 4:28 AM, Marco Hugentobler wrote the Qgis slow start up was a detrimental "side effect of my changes for large format printing."
> On Jan 22, 2010, at 5:57 AM, Marco Hugentobler wrote "r12815 contains a fix for the multiband display problem."
> On Jan 22, 2010, at 9:58 AM, William Kyngesburye wrote that Marco's r12815 "fixed the speed problem opening Greg's sample project!"
> On Jul 2, 2010, at 10:51 AM, Greg Coats wrote that
> Qgis r13519 opens the Qgis project in 2 seconds
> Qgis r13597 opens the Qgis project in 360 seconds
> Qgis r13878 opens the Qgis project in 400 seconds
> Greg
> On Jul 5, 2010, at 5:10 AM, Giovanni Manghi wrote:
>> Hi Greg,
>> why don't you post somewhere the project file with a sample of the data
>> so we can try reproduce on other machines?
>> cheers
>> -- Giovanni --
>> On Mon, 2010-07-05 at 00:01 -0400, Greg Coats wrote:
>>> Under Mac OS X 10.6.4, Qgis revision 13519 downloaded on 2010-05-25
>>> from http://www.kyngchaos.com/software/qgis opens a Qgis project in 2
>>> seconds, while just opening the same Qgis project with Qgis revision
>>> 13878 downloaded on 2010-07-04
>>> from http://www.kyngchaos.com/oftware/qgis keeps the CPU 100% busy for
>>> 400 seconds. This is the same bug Qgis had back on 2010-01-10. It is
>>> disappointing to see this serious bug return to Qgis. Greg
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
