[Qgis-user] Serious bug returns to Qgis revision 13878
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Jul 5 23:35:52 PDT 2010
Hi William
Ah, good to know it is the icon generation that makes loading projects with
many raster layers slow.
Making a user option to disable layer icons sounds good. However, this would
involve a string change (option dialog). String freeze for 1.5 is already over
for a while now. So (unless there is a better solution for the problem without
string change) something for 1.6...
Regards,
Marco
Am Montag, 5. Juli 2010, um 19.51:53 schrieb William Kyngesburye:
> I poked around a bit - looks like only 1 change between r13519 and r13597:
> r13570, reenabling raster legend icons. I reverted this change (local
> copy) and the project again loads fast.
> Nothing else I can do, hopefully Marco can figure something out. Maybe
> cache the icons in the project, or an option to turn raster legend icons
> off, or something else to speed up the process?
> On Jul 5, 2010, at 10:35 AM, Greg Coats wrote:
> > After weeks of direct (non-public) discussions, on Jan 18, 2010, at 12:50
> > AM, I first publicly posted the Qgis slow start up issue under Subject:
> > Qgis slow start up, and noted that a small 14 MB sample Qgis project can
> > be download from
> > http://homepage.mac.com/gregcoats/jp2/images/dcua_reduce4_03.zip
> > On Jan 22, 2010, at 4:28 AM, Marco Hugentobler wrote the Qgis slow start
> > up was a detrimental "side effect of my changes for large format
> > printing."
> > On Jan 22, 2010, at 5:57 AM, Marco Hugentobler wrote "r12815 contains a
> > fix for the multiband display problem."
> > On Jan 22, 2010, at 9:58 AM, William Kyngesburye wrote that Marco's
> > r12815 "fixed the speed problem opening Greg's sample project!"
> > On Jul 2, 2010, at 10:51 AM, Greg Coats wrote that
> > Qgis r13519 opens the Qgis project in 2 seconds
> > Qgis r13597 opens the Qgis project in 360 seconds
> > Qgis r13878 opens the Qgis project in 400 seconds
> > Greg
> > On Jul 5, 2010, at 5:10 AM, Giovanni Manghi wrote:
> >> Hi Greg,
> >> why don't you post somewhere the project file with a sample of the data
> >> so we can try reproduce on other machines?
> >> cheers
> >> -- Giovanni --
> >> On Mon, 2010-07-05 at 00:01 -0400, Greg Coats wrote:
> >>> Under Mac OS X 10.6.4, Qgis revision 13519 downloaded on 2010-05-25
> >>> from http://www.kyngchaos.com/software/qgis opens a Qgis project in 2
> >>> seconds, while just opening the same Qgis project with Qgis revision
> >>> 13878 downloaded on 2010-07-04
> >>> from http://www.kyngchaos.com/oftware/qgis keeps the CPU 100% busy for
> >>> 400 seconds. This is the same bug Qgis had back on 2010-01-10. It is
> >>> disappointing to see this serious bug return to Qgis. Greg
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> First Pogril: Why is life like sticking your head in a bucket filled with
> hyena offal? Second Pogril: I don't know. Why IS life like sticking your
> head in a bucket filled with hyena offal? First Pogril: I don't know
> either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Webereistrasse 66, 8134 Adliswil, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
