[Qgis-user] Serious bug returns to Qgis revision 13878
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Jul 6 00:18:24 PDT 2010
Hi Werner
I think it should be release manager's (Tims) decision if this string can
still be added to the option dialog.
Regards,
Marco
Am Dienstag, 6. Juli 2010, um 08.50:27 schrieb Werner Macho:
> Hi Marco!
> As there were already a few string changes after string freeze - and it
> seems that devs does not take string freeze very serious ;) - I suggest
> to change this one more string for 1.5. (As long as it is really just
> one string)
> And I promise that I take more care on string changes after string
> freeze for 1.6 (just revert any string change after string freeze)
> What are you thinking about this?
> Regards,
> Werner
> Am 06.07.2010 08:35, schrieb Marco Hugentobler:
> > Hi William
> > Ah, good to know it is the icon generation that makes loading projects
> > with many raster layers slow.
> > Making a user option to disable layer icons sounds good. However, this
> > would involve a string change (option dialog). String freeze for 1.5 is
> > already over for a while now. So (unless there is a better solution for
> > the problem without string change) something for 1.6...
> > Regards,
> > Marco
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Webereistrasse 66, 8134 Adliswil, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
