[Qgis-user] Can QGIS plot single line segments?
Tim Keitt
tkeitt at gmail.com
Mon Jul 19 20:04:58 PDT 2010
I have what I think is a perfectly good shape file. ogrinfo returns
NFO: Open of `jagmesh.shp'
using driver `ESRI Shapefile' successful.
Layer name: jagmesh
Geometry: Line String
Feature Count: 19047
Extent: (-3547484.000000, -5785886.000000) - (4866967.000000, 3747255.000000)
Layer SRS WKT:
PROJCS["Lambert_Azimuthal_Equal_Area",
GEOGCS["unnamed ellipse",
DATUM["unknown",
SPHEROID["Unknown",6370997,0]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",0],
PARAMETER["longitude_of_center",-80],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
is.edge.so: Real (11.0)
is.edge.ta: Real (11.0)
I loaded it into postgis. The first 5 lines are:
gid | astext
1 | LINESTRING(-118068.9 -658036.18355628,-118068.9 -658036.18355628)
2 | LINESTRING(-120565.103973043 -652437.1,-120565.103973043 -652437.1)
3 | LINESTRING(-108926.6 -648353.4,-108926.6 -648353.4)
4 | LINESTRING(3666461.07939581 -119248.798562935,3666461.07939581
-119248.798562935)
5 | LINESTRING(3636409.07468477 -129061.988213268,3636409.07468477
-129061.988213268)
(5 rows)
Neither the shapefile or the postgis table will display in QGIS. QGIS
clearly digests the data and looks like it wants to draw something,
but the plot is blank.
THK
Timothy H. Keitt
http://www.keittlab.org/
