[Qgis-user] Can QGIS plot single line segments?
Tim Keitt
tkeitt at gmail.com
Tue Jul 20 06:11:43 PDT 2010
Ah, good catch. I must have accidentally duplicated the node indices
when constructing the lines.
THK
On Tue, Jul 20, 2010 at 12:47 AM, Gavin Macaulay <gavin at macaulay.co.nz> wrote:
> Tim Keitt wrote:
>> I have what I think is a perfectly good shape file. ogrinfo returns
>> NFO: Open of `jagmesh.shp'
>> using driver `ESRI Shapefile' successful.
>> Layer name: jagmesh
>> Geometry: Line String
>> Feature Count: 19047
>> Extent: (-3547484.000000, -5785886.000000) - (4866967.000000,
>> 3747255.000000)
>> Layer SRS WKT:
>> PROJCS["Lambert_Azimuthal_Equal_Area",
>> GEOGCS["unnamed ellipse",
>> DATUM["unknown",
>> SPHEROID["Unknown",6370997,0]],
>> PRIMEM["Greenwich",0],
>> UNIT["Degree",0.017453292519943295]],
>> PROJECTION["Lambert_Azimuthal_Equal_Area"],
>> PARAMETER["latitude_of_center",0],
>> PARAMETER["longitude_of_center",-80],
>> PARAMETER["false_easting",0],
>> PARAMETER["false_northing",0],
>> UNIT["Meter",1]]
>> is.edge.so: Real (11.0)
>> is.edge.ta: Real (11.0)
>> I loaded it into postgis. The first 5 lines are:
>> gid | astext
>> 1 | LINESTRING(-118068.9 -658036.18355628,-118068.9 -658036.18355628)
>> 2 | LINESTRING(-120565.103973043 -652437.1,-120565.103973043 -652437.1)
>> 3 | LINESTRING(-108926.6 -648353.4,-108926.6 -648353.4)
>> 4 | LINESTRING(3666461.07939581 -119248.798562935,3666461.07939581
>> -119248.798562935)
>> 5 | LINESTRING(3636409.07468477 -129061.988213268,3636409.07468477
>> -129061.988213268)
>> (5 rows)
>> Neither the shapefile or the postgis table will display in QGIS. QGIS
>> clearly digests the data and looks like it wants to draw something,
>> but the plot is blank.
>> THK
> Tim,
> The 5 linestrings that you gave as an example are all of zero length. Hence
> if all 19407 linestrings have that property, what qgis is displaying is
> appropriate.
> Regards
> Gavin
> Qgis-user mailing list
Timothy H. Keitt
http://www.keittlab.org/
