[Qgis-user] (no subject)
Noli Sicad nsicad at gmail.com
Sun Jul 25 18:08:34 PDT 2010
I think this problem is very typical problem for plugins with
dependencies with other python packages.
It would have been better if plugins would show the dependecies
message so user could download and install the package.
In this case, just tell the user to download and install the matplotlib package.
http://matplotlib.sourceforge.net/users/installing.html
Noli
On 7/26/10, Carson Farmer <carson.farmer at gmail.com> wrote:
> Except that will remove all plugins! What you probably really want is:
> rm -rf /Users/hermanpalaquium/.qgis/python/plugins/contour
> Which will only remove the contour plugin, which is failing to load
> because matplotlib isn't installed...
> I think you can also do this from the Python plugin installer by
> selecting to remove the plugin?
> Carson
>> Traceback (most recent call last):
>>   File
>> "/Applications/Qgis.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>> line 119, in loadPlugin
>>     __import__(packageName)
>>   File "/Users/hermanpalaquium/.qgis//python/plugins/contour/__init__.py",
>> line 28, in
>>     from contour import Contour
>>   File "/Users/hermanpalaquium/.qgis//python/plugins/contour/contour.py",
>> line 38, in
>>     import matplotlib.pyplot as plt
>> ImportError: No module named matplotlib.pyplot
> Carson J. Q. Farmer
> ISSP Doctoral Fellow
> National Centre for Geocomputation
> National University of Ireland, Maynooth,
> http://www.carsonfarmer.com/
> Qgis-user mailing list
