[Qgis-user] Re: Grayscale GeoTiff and transparency using GDAL.
Pietro Panzeri
pietro.panzeri at treuropa.com
Thu Jun 3 03:57:13 PDT 2010
No one has a solution?
Thank you.
On Mon, May 31, 2010 at 10:42 AM, Pietro Panzeri <
pietro.panzeri at treuropa.com> wrote:
> Hi all,
> I'm writing a plugin using GDAL C library to allow the user to create a
> grayscale GeoTiff with transparency.
> I've used the following code to init the raster:
> Driver = GDALGetDriverByName("GTiff");
> papszOptions = CSLSetNameValue(papszOptions, "COMPRESS", "LZW");
> Dataset = GDALCreate(Driver, SrcFilename, XSize, YSize, 2, GDT_Byte,
> papszOptions);
> Band1 = GDALGetRasterBand(Dataset, 1);
> GDALSetRasterColorInterpretation(Band1, GCI_GrayIndex);
> Band2 = GDALGetRasterBand(Dataset, 2);
> GDALSetRasterColorInterpretation(Band2, GCI_AlphaBand);
> Init the two bands
> The result is a correct grayscale image but without transparency.
> Can someone point me a way to create a grayscale GeoTiff with a
> transparency?
> Thank you very much.
> Pietro
> Pietro Panzeri
> Software Development Manager
> Tele-Rilevamento Europa - T.R.E. srl
> Via Vittoria Colonna, 7
> 20149 Milano – Italia
> Tel.: +39.02.4343.121 - Fax: +39.02.4343.1230
> pietro.panzeri at treuropa.com - www.treuropa.com
Pietro Panzeri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100603/f4adf476/attachment.html>
