[Qgis-user] Re: Grayscale GeoTiff and transparency using GDAL.
Anders Söderman
Anders.Soderman at gisassistans.se
Thu Jun 3 04:30:32 PDT 2010
Perhaps this helps. Good luck. //Anders Söderman Sweden
http://www.gdal.org/frmt_gtiff.html
Internal nodata masks (from GDAL 1.6.0)
TIFF files can contain internal transparency masks. The GeoTIFF driver
recognizes an internal directory as being a transparency mask when the
FILETYPE_MASK bit value is set on the TIFFTAG_SUBFILETYPE tag. According to
the TIFF specification, such internal transparency masks contain 1 sample of
1-bit data. Although the TIFF specification allows for higher resolutions
for the internal transparency mask, the GeoTIFF driver only supports
internal transparency masks of the same dimensions as the main image.
Transparency masks of internal overviews are also supported
When the GDAL_TIFF_INTERNAL_MASK environment variable is set to YES and the
GeoTIFF file is opened in update mode, the CreateMaskBand() method on a TIFF
dataset or rasterband will create an internal transparency mask. Otherwise,
the default behaviour of nodata mask creation will be used, that is to say
the creation of a .msk file, as per RFC 15
_____
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Pietro Panzeri
Sent: den 3 juni 2010 12:57
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Re: Grayscale GeoTiff and transparency using GDAL.
No one has a solution?
Thank you.
On Mon, May 31, 2010 at 10:42 AM, Pietro Panzeri
<pietro.panzeri at treuropa.com> wrote:
Hi all,
I'm writing a plugin using GDAL C library to allow the user to create a
grayscale GeoTiff with transparency.
I've used the following code to init the raster:
Driver = GDALGetDriverByName("GTiff");
papszOptions = CSLSetNameValue(papszOptions, "COMPRESS", "LZW");
Dataset = GDALCreate(Driver, SrcFilename, XSize, YSize, 2, GDT_Byte,
papszOptions);
Band1 = GDALGetRasterBand(Dataset, 1);
GDALSetRasterColorInterpretation(Band1, GCI_GrayIndex);
Band2 = GDALGetRasterBand(Dataset, 2);
GDALSetRasterColorInterpretation(Band2, GCI_AlphaBand);
Init the two bands
The result is a correct grayscale image but without transparency.
Can someone point me a way to create a grayscale GeoTiff with a
transparency?
Thank you very much.
Pietro
Pietro Panzeri
Software Development Manager
Tele-Rilevamento Europa - T.R.E. srl
Via Vittoria Colonna, 7
20149 Milano Italia
Tel.: +39.02.4343.121 - Fax: +39.02.4343.1230
pietro.panzeri at treuropa.com - www.treuropa.com
Pietro Panzeri
20149 Milano Italia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100603/7748fe33/attachment.html>
