[Qgis-user] Points2one - group by input field
Goyo
goyodiaz at gmail.com
Sun Jun 6 05:40:17 PDT 2010
El dom, 06-06-2010 a las 13:58 +0200, MORREALE Jean Roc escribió:
> Le 05/06/2010 21:00, Goyo a écrit :
> > El vie, 04-06-2010 a las 14:47 +0200, MORREALE Jean Roc escribió:
> >> It would be great if the plugin could parse the file, group the
> >> feature points sequentially by the input field and only then draw
> >> the polygon as it would allows a surveyer to stop collecting a long
> >> feature to collect a small nearby feature and then resume on the
> >> previous one.
> > Please install version 0.2.2 of the plugin and see if it does what
> > you need. It allows you to sort the points by the grouping attribute.
> > You'll find it in the plugin installer.
> Hi goyo,
> Unfortunately I can't test the version "0.2.2 (0.2.0)", when installing
> I get this error :
> "The plugin seems to have been installed but I don't know where.
> Probably the plugin package contained a wrong named directory.
> Please search the list of installed plugins. I'm nearly sure you'll find
> the plugin there, but I just can't determine which of them it is. It
> also means that I won't be able to determine if this plugin is installed
> and inform you about available updates. However the plugin may work.
> Please contact the plugin author and submit this issue."
> And this on clean qgis install without the previous version of
> points2one (0.2.0), which is still showing up in the list), the folder
> is created and filled in ~/.qgis/python/plugins.
I'll try to fix this. But the plugin should work anyway. Can you go to
Plugins > Manage plugins and and check whether Points2One is listed and
can be activated?
Goyo
