[Qgis-user] Points2one - group by input field
MORREALE Jean Roc
jr.morreale at enoreth.net
Sun Jun 6 06:23:01 PDT 2010
Le 06/06/2010 14:40, Goyo a écrit :
> El dom, 06-06-2010 a las 13:58 +0200, MORREALE Jean Roc escribió:
>> Le 05/06/2010 21:00, Goyo a écrit :
>>> El vie, 04-06-2010 a las 14:47 +0200, MORREALE Jean Roc escribió:
>>>> It would be great if the plugin could parse the file, group the
>>>> feature points sequentially by the input field and only then draw
>>>> the polygon as it would allows a surveyer to stop collecting a long
>>>> feature to collect a small nearby feature and then resume on the
>>>> previous one.
>>> Please install version 0.2.2 of the plugin and see if it does what
>>> you need. It allows you to sort the points by the grouping attribute.
>>> You'll find it in the plugin installer.
>> Hi goyo,
>> Unfortunately I can't test the version "0.2.2 (0.2.0)", when installing
>> I get this error :
>> "The plugin seems to have been installed but I don't know where.
>> Probably the plugin package contained a wrong named directory.
>> Please search the list of installed plugins. I'm nearly sure you'll find
>> the plugin there, but I just can't determine which of them it is. It
>> also means that I won't be able to determine if this plugin is installed
>> and inform you about available updates. However the plugin may work.
>> Please contact the plugin author and submit this issue."
>> And this on clean qgis install without the previous version of
>> points2one (0.2.0), which is still showing up in the list), the folder
>> is created and filled in ~/.qgis/python/plugins.
> I'll try to fix this. But the plugin should work anyway. Can you go to
> Plugins> Manage plugins and and check whether Points2One is listed and
> can be activated?
> Goyo
Points2One is effectively available in the plugin manager and is working
great ! Thank you for this modification
