[Qgis-user] Problems using OSM plugin
Carlos Dávila cdavilam at orangecorreo.es
Sun Jun 6 10:54:31 PDT 2010
I'm trying to use OSM pluging for editing data for the first time and am
facing some problems:
1- When I upload edited data I get the error below, no matter if I edit
a saved osm file or freshly downloaded data:
Upload process failed. OpenStreetMap server response: Bad Request -
Cannot parse valid way from xml string <?xml version="1.0"
encoding="UTF-8"?><osm version="0.6" generator="OpenStreetMap
server"><way id="23108300" visible="true"
timestamp="2010-04-05T10:50:23Z" user="antecessor" version="10"
changeset="4919909"><nd ref="248219762"/><nd ref="248219763"/><nd
ref="248219764"/><nd ref="248219765"/><nd ref="248219766"/><nd
ref="248219767"/><nd ref="248219768"/><nd ref="248219769"/><nd
ref="248219770"/><nd ref="248219771"/><nd ref="412472837"/><nd
ref="248219772"/><nd ref="248219773"/><nd ref="412472711"/><nd
ref="447083532"/><nd ref="685164049"/><nd ref="447083436"/><nd
ref="685164046"/><nd ref="248219776"/><nd ref="248219777"/><nd
ref="248219778"/><nd ref="248219779"/><tag k="highway" v="primary"/><tag
k="lanes" v="2"/><tag k="name" v="Carretera de Cáceres a Villanueva de
la Serena"/><tag k="oneway" v="no"/><tag k="ref" v="EX-206"/><tag
k="source" v="survey"/><tag k="surface" v="asphalt"/></way></osm>. Fatal
error: Input is not proper UTF-8, indicate encoding !.
How should I indicate encoding?
2- When using "Move feature" tool, after selecting a feature, any mouse
movement causes a Python error:
Ha ocurrido un error mientras se ejecutaba el código de Python:
   File
"/usr/local/qgis/share/qgis/python/plugins/osm/map_tools/OsmMoveMT.py",
line 587, in canvasMoveEvent
     (deltaX,deltaY)=self.__getDeltaForPoint(event)    # snapping is
done in this function
   File
line 648, in __getDeltaForPoint
     (self.snapFeat,self.snapFeatType)=self.dbm.findFeature(snappedPoint)
TypeError: 'NoneType' object is not iterable
Versión de Python:
2.6.5+ (release26-maint, May 30 2010, 13:56:50)
[GCC 4.4.4]
Versión de QGIS:
1.5.0-Trunk Trunk, 13635M
Ruta de Python: ['/usr/local/qgis/share/qgis/python',
'/home/carlos/.qgis/python', '/home/carlos/.qgis/python/plugins',
'/usr/local/qgis/share/qgis/python/plugins', '/usr/lib/python2.6',
'/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
'/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
'/usr/lib/python2.6/dist-packages',
'/usr/lib/python2.6/dist-packages/PIL',
'/usr/lib/python2.6/dist-packages/gst-0.10',
'/usr/lib/pymodules/python2.6',
'/usr/lib/python2.6/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.6/gtk-2.0',
'/usr/local/lib/python2.6/dist-packages',
u'/home/carlos/.qgis//python/plugins',
'/usr/local/qgis/share/qgis/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100606/a1f2d24e/attachment.html>
