[Qgis-user] proj4 definition for European Forest Map
Agustin Lobo
alobolistas at gmail.com
Mon Jun 21 02:47:44 PDT 2010
Hi!
The European Forest Map has the following projection:
Projection: Lambert_Azimuthal_Equal_Area
Parameters:
False_Easting: 0.000000
False_Northing: 0.000000
Central_Meridian: 9.000000
Latitude_Of_Origin: 48.000000
Linear Unit: Meter (1.000000)
Coordinate system
Geographic Coordinate System:
Angular Unit: Degree (0.017453292519943299)
Prime Meridian: Greenwich (0.000000000000000000)
Datum: D_User_Defined
Spheroid: User_Defined_Spheroid
Semimajor Axis: 6378388.000000000000000000
Semiminor Axis: 6378388.000000000000000000
Inverse Flattening: 0.000000000000000000
I've made several trials to set up a custom projection:
1.
+proj=laea +lat_0=48 +lon_0=9 +x_0=0.000 +y_0=0.000 +a=6378388.0000
+b=6378388.000 +rf=0.000 +units=m +no_defs
Rejected by the custom projection tool as erroneous
2.
+b=6378388.000 +f=0.000 +units=m +no_defs
Accepted by the custom projection tool but the Properties dialog does
not accept it
3.
+b=6378388.000 +units=m +no_defs
Seems to work fine.
I'd like if someone could actually confirm that the third proj4
definition is actually
in accordance with the definition provided in the server and that I
have reproduced at the beginning of this
message.
Thanks!
Agus
