[Qgis-user] Attribute Join problem in PostgreSQL
Micha Silver
micha at arava.co.il
Thu Jun 24 06:30:01 PDT 2010
On 06/24/2010 02:04 PM, Hemayet Hossain wrote:
> Hi
> I have imported a shape file into QGis and then did attribute join
> (under menu Vector>Data Management Tools>Join Attribute) to add some
> additional attributes and it worked perfectly. I then imported the
> same shape file into PostgreSQL/PostGis using SPIT plugin in QGis and
> then tried to do attribute join folloeing same procedure - it did not
> work. It seems that Join Attribute will not work if the data is in
> PostgreSQL/PostGIS DBMS. Any suggestion?
As far as I know, the Join Attribute feature in Vector tools is only for
dbf tables. What you'll have to do is import your additional attribute
table also to PostGIS, then do the join within Postgres with database
mamangement tools (i.e. using the PostGIS Manager Plugin in QGIS).
Micha
> Hem
> ________________________
> Hemayet Hossain, D.Env.D
> Land, Tenure and Property Administration Section
> Shelter Branch, Global Division
> UN-HABITAT
> P.O. Box 30030, Nairobi 00100, Kenya
> Tel: + 254 (20) 762 3705
> Fax: +254 (20) 762 4265
> email: hemayet.hossain at unhabitat.org
> Website: www.unhabitat.org
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100624/70bf6169/attachment.html>
