[Qgis-user] Attribute Join problem in PostgreSQL
Hemayet Hossain Hemayet.Hossain at unhabitat.org
Thu Jun 24 04:04:50 PDT 2010
Hi
I have imported a shape file into QGis and then did attribute join (under
menu Vector>Data Management Tools>Join Attribute) to add some additional
attributes and it worked perfectly. I then imported the same shape file
into PostgreSQL/PostGis using SPIT plugin in QGis and then tried to do
attribute join folloeing same procedure - it did not work. It seems that
Join Attribute will not work if the data is in PostgreSQL/PostGIS DBMS.
Any suggestion?
Hem
________________________
Hemayet Hossain, D.Env.D
Land, Tenure and Property Administration Section
Shelter Branch, Global Division
UN-HABITAT
P.O. Box 30030, Nairobi  00100, Kenya
Tel: + 254 (20) 762 3705
Fax: +254 (20) 762 4265
email: hemayet.hossain at unhabitat.org
Website: www.unhabitat.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100624/1aad5a55/attachment.html>
