[Qgis-user] attribute table - area
Giovanni Manghi
giovanni.manghi at gmail.com
Sun Mar 14 09:06:33 PDT 2010
Olá Orlando, tudo bem?
> When creating a theme of polygons, it is possible the area of the
> polygon automatically appear in the attribute
> table?
yes you can,
just create a postgis polygon layer and add a trigger to the column
where you want to store the area value. You can do it without leaving
qgis with the postgis manager plugin.
> Without having to make manual measurements with this tool: Measure
> Area.
you don't need this tool to calculate areas, you can do it with the
field calculator or with the "export/add geometry columns" of the vector
menu.
abraços
-- Giovanni --
