[Qgis-user] Edit UI
Mike Toews
mwtoews at gmail.com
Mon Mar 15 15:37:48 PDT 2010
If you had to lean anything useful, learn how to use
PostgreSQL/PostGIS. You can easily set defaults for the database
columns to automagically enter data, for example you want "now()" (or
possibly "now()::date" for just the date and not the full timestamp).
There are many other fun/useful things in the database world that you
can do with QGIS (triggers, views, functions, etc.), but you don't
need to dive into the deep yet to do simple things, like your task.
-Mike
2010/3/15 Einar Guðsteinsson <einsigu at simnet.is>
> Ouch, one dev tool more to learn.... when day will be 26 hours :-) Can I use action or something else to set default value? one field is string with date and I want today always to be automaticly filled in.
> Einar
> From: "Alex Mandel" <tech_dev at wildintellect.com>
> Sent: Monday, March 15, 2010 9:32 PM
> To: <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Edit UI
>> Einar Gušsteinsson wrote:
>>> Hi´
>>> Got shapefiles that I would like to create my own edit screen for. Edit UI field in layer option is there but how do I create .ui file??
>>> best regards
>>> Einar
>> UI files are made using Qt toolkit.
>> http://qt.nokia.com/products/developer-tools
>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
