[Qgis-user] Re: QGIS1.4.0 With GRASS - Windows Installer
Giovanni Manghi
giovanni.manghi at gmail.com
Fri Mar 19 05:51:16 PDT 2010
Hi Agus,
there are (were) a couple of problems.
One was solved yesterday, you'll need to use qgis-dev to see the pyhton
gdal utilities in the gdal_tools plugin work.
The other is about the .exe gdal utilities under Vista/Seven: I believe
they are working on it. Meanwhile you just need to delete the file
gdal_GRASS.dll in your osgeo4w installation.
cheers
-- Giovanni --
On Thu, 2010-03-18 at 23:57 -0800, Agustin Lobo wrote:
> Thanks,
> According to what I've been able to test up to now,
> some programs in the Raster tab do not work:
> Traceback (most recent call last):
> File "C:\QuantumGIS-1.4\apps\gdal-16\bin\gdal_proximity.py", line 35, in
> import gdal
> File "C:\osgeo\apps\Python25\lib\site-packages\gdal.py", line 2, in
> File "C:\osgeo\apps\Python25\lib\site-packages\osgeo\gdal.py", line 7, in
> ImportError: No module named _gdal
> File "C:\QuantumGIS-1.4\apps\gdal-16\bin\gdal_polygonize.py", line 34, in
> import gdal, ogr, osr
> Instead, contour, RasterCalc and Raster-based terrain analysis work fine
> I'll keep you posted ofany errors I find.
> Agus
