[Qgis-user] Re: QGIS1.4.0 With GRASS - Windows Installer
Agustin Lobo alobolistas at gmail.com
Fri Mar 19 09:48:26 PDT 2010
Giovanni,
My message was regarding the standalone version
of QGIS provided by Kumaran
http://kcubeconsulting.com/download.php
The osgeo4w is really not an option for a course (actually
I think that users able to deal with such installation are
able to deal with a linux distribution which would imply
many other advantages, but this is another story).
Thanks!
Agus
Giovanni Manghi [via OSGeo.org] wrote:
> Hi Agus,
> there are (were) a couple of problems.
> One was solved yesterday, you'll need to use qgis-dev to see the pyhton
> gdal utilities in the gdal_tools plugin work.
> The other is about the .exe gdal utilities under Vista/Seven: I believe
> they are working on it. Meanwhile you just need to delete the file
> gdal_GRASS.dll in your osgeo4w installation.
> cheers
> -- Giovanni --
> On Thu, 2010-03-18 at 23:57 -0800, Agustin Lobo wrote:
>  > Thanks,
>  > According to what I've been able to test up to now,
>  > some programs in the Raster tab do not work:
>  > Traceback (most recent call last):
>  > File "C:\QuantumGIS-1.4\apps\gdal-16\bin\gdal_proximity.py", line 35, in
>  > import gdal
>  > File "C:\osgeo\apps\Python25\lib\site-packages\gdal.py", line 2, in
>  > File "C:\osgeo\apps\Python25\lib\site-packages\osgeo\gdal.py", line
> 7, in
>  > ImportError: No module named _gdal
>  > File "C:\QuantumGIS-1.4\apps\gdal-16\bin\gdal_polygonize.py", line
> 34, in
>  > import gdal, ogr, osr
> 7, in
>  > Instead, contour, RasterCalc and Raster-based terrain analysis work fine
>  > I'll keep you posted ofany errors I find.
>  > Agus
> Qgis-user mailing list
> [hidden email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4762643&i=0>
> View message @
> http://n2.nabble.com/QGIS1-3-0-Mimas-With-GRASS-Windows-Installer-tp4121469p4762643.html
> To unsubscribe from Re: QGIS1.4.0 With GRASS - Windows Installer, click
> here
> < (link removed) =>.
View this message in context: http://n2.nabble.com/QGIS1-3-0-Mimas-With-GRASS-Windows-Installer-tp4121469p4764205.html
Sent from the qgis-user mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100319/cce66575/attachment.html>
