[Qgis-user] Re: Quick Print with QGis 1.5
Giovanni Manghi
giovanni.manghi at gmail.com
Fri Oct 1 03:28:28 PDT 2010
> One wish I have is to make Easy Print work with the Openlayers plugin.
> When I use it, the Google basemap either disappears or the vectors
> are plotted in the wrong place. The same thing happens when I use the
> Print Composer.
the openlayers plugin is know to not work yet correctly in the print
composer, so it will not work also in the easy print plugin.
cheers
-- Giovanni --
