[Qgis-user] QGIS 1.5 - Ability to set WMS provider version?
Jürgen E. Fischer
jef at norbit.de
Fri Oct 1 08:19:51 PDT 2010
Hi David,
On Fri, 01. Oct 2010 at 10:11:40 -0500, David Fawcett wrote:
> I have successfully used QGIS to consume WMS v 1.1 services in the
> past, but I can't seem to get them to work with QGIS 1.5.0 (WinXP via
> OSGEO4W built against 13923M). The server is advertising only WMS
> version 1.1 in the getCapabilities doc, but QGIS is using "OGC Web Map
> Service version 1.3 data provider".
> I can't find anywhere to manually set the correct WMS data provider.
That's just a static string from QGIS' only WMS provider. Which problems
are you actually seeing? And is that WMS public so other could try to
reproduce?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
