[Qgis-user] Using shell grass windows.
Kenneth Roy Cabrera Torres
krcabrer at une.net.co
Mon Oct 4 07:33:54 PDT 2010
Hi qgis users:
I try to make a "d.mon x0" instruction on the grass shell window,
but it shows me the following message:
using default visual which is TrueColor
ncolors: 16777216
ERROR: No ha sido posible recuperar el valor de la variable de entorno
GIS_LOCK.
GIS_LOCK.
Problema al seleccionar x0. Se intentarĂ¡ otra vez
GIS_LOCK.
In english is something like this:
ncolors: 16777216
ERROR: Unable to get GIS_LOCK enviroment variable value
Problem selecting x0. Will try once more
When I begin with qgis I use 1.4.0 qgis version and this
options works fine.
The shell grass window change also. I use to have this window:
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS 6.4.1svn (2010)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui tcltk
When ready to quit enter: exit
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
But now I only obtain this prompt:
kenneth at kenneth-desktop:~$
And nothing else.
What should I do to solve this problem.
Thank you for your help.
Kenneth
