[Qgis-user] Using shell grass windows.
Micha Silver
micha at arava.co.il
Fri Oct 8 13:04:32 PDT 2010
On 10/04/2010 04:33 PM, Kenneth Roy Cabrera Torres wrote:
> Hi qgis users:
> I try to make a "d.mon x0" instruction on the grass shell window,
> but it shows me the following message:
I think you cannot use any of the d.* commands from within QGIS. Once
you've opened a GRASS session then the display is redirected to the QGIS
canvas.
If you want to work this way (with the d.* commands) run GRASS natively,
without QGIS.
> using default visual which is TrueColor
> ncolors: 16777216
> ERROR: No ha sido posible recuperar el valor de la variable de entorno
> GIS_LOCK.
> But now I only obtain this prompt:
> kenneth at kenneth-desktop:~$
> And nothing else.
There's no problem. Just type in GRASS commands and it should work.
Micha
> What should I do to solve this problem.
> Thank you for your help.
> Kenneth
> Qgis-user mailing list
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
