[Qgis-user] Using shell grass windows.
Kenneth Roy Cabrera Torres
krcabrer at une.net.co
Fri Oct 8 17:32:05 PDT 2010
Thank you Micha for you advice.
I use to work in older version with d.* commands inside qgis,
I was wondering why I cannot work this way any more.
Thank you.
El vie, 08-10-2010 a las 22:04 +0200, Micha Silver escribió:
> On 10/04/2010 04:33 PM, Kenneth Roy Cabrera Torres wrote:
> > Hi qgis users:
> > I try to make a "d.mon x0" instruction on the grass shell window,
> > but it shows me the following message:
> I think you cannot use any of the d.* commands from within QGIS. Once
> you've opened a GRASS session then the display is redirected to the QGIS
> canvas.
> If you want to work this way (with the d.* commands) run GRASS natively,
> without QGIS.
> > using default visual which is TrueColor
> > ncolors: 16777216
> > ERROR: No ha sido posible recuperar el valor de la variable de entorno
> > GIS_LOCK.
> > But now I only obtain this prompt:
> > kenneth at kenneth-desktop:~$
> > And nothing else.
> There's no problem. Just type in GRASS commands and it should work.
> Micha
> > What should I do to solve this problem.
> > Thank you for your help.
> > Kenneth
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > This mail was received via Mail-SeCure System.
