[Qgis-user] Using shell grass windows.
Radim Blazek radim.blazek at gmail.com
Sat Oct 9 11:10:16 PDT 2010
GIS_LOCK is set by init.sh to PID and used to create socket path, try
export GIS_LOCK=$$
from the GRASS shell.
Radim
On Sat, Oct 9, 2010 at 2:32 AM, Kenneth Roy Cabrera Torres
<krcabrer at une.net.co> wrote:
> Thank you Micha for you advice.
> I use to work in older version with d.* commands inside qgis,
> I was wondering why I cannot work this way any more.
> Thank you.
> El vie, 08-10-2010 a las 22:04 +0200, Micha Silver escribió:
>> On 10/04/2010 04:33 PM, Kenneth Roy Cabrera Torres wrote:
>> > Hi qgis users:
>> > I try to make a "d.mon x0" instruction on the grass shell window,
>> > but it shows me the following message:
>> I think you cannot use any of the d.* commands from within QGIS. Once
>> you've opened a GRASS session then the display is redirected to the QGIS
>> canvas.
>> If you want to work this way (with the d.* commands) run GRASS natively,
>> without QGIS.
>> > using default visual which is TrueColor
>> > ncolors: 16777216
>> > ERROR: No ha sido posible recuperar el valor de la variable de entorno
>> >         GIS_LOCK.
>> > But now I only obtain this prompt:
>> > kenneth at kenneth-desktop:~$
>> > And nothing else.
>> There's no problem. Just type in GRASS commands and it should work.
>> Micha
>> > What should I do to solve this problem.
>> > Thank you for your help.
>> > Kenneth
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > This mail was received via Mail-SeCure System.
