[Qgis-user] Using shell grass windows.
Kenneth Roy Cabrera Torres
krcabrer at une.net.co
Sat Oct 9 19:34:52 PDT 2010
Thank you Radim.
It works!!
Thank you for your help!
Now I can do somethings that in qgis I cannot display,
for example in a vector lines layers I can not display
the arrows for the direcctions of the lines.
Thank you very much.
Kenneth
El sáb, 09-10-2010 a las 20:10 +0200, Radim Blazek escribió:
> GIS_LOCK is set by init.sh to PID and used to create socket path, try
> export GIS_LOCK=$$
> from the GRASS shell.
> Radim
> On Sat, Oct 9, 2010 at 2:32 AM, Kenneth Roy Cabrera Torres
> <krcabrer at une.net.co> wrote:
> > Thank you Micha for you advice.
> > I use to work in older version with d.* commands inside qgis,
> > I was wondering why I cannot work this way any more.
> > Thank you.
> > El vie, 08-10-2010 a las 22:04 +0200, Micha Silver escribió:
> >> On 10/04/2010 04:33 PM, Kenneth Roy Cabrera Torres wrote:
> >> > Hi qgis users:
> >> > I try to make a "d.mon x0" instruction on the grass shell window,
> >> > but it shows me the following message:
> >> I think you cannot use any of the d.* commands from within QGIS. Once
> >> you've opened a GRASS session then the display is redirected to the QGIS
> >> canvas.
> >> If you want to work this way (with the d.* commands) run GRASS natively,
> >> without QGIS.
> >> > using default visual which is TrueColor
> >> > ncolors: 16777216
> >> > ERROR: No ha sido posible recuperar el valor de la variable de entorno
> >> > GIS_LOCK.
> >> > But now I only obtain this prompt:
> >> > kenneth at kenneth-desktop:~$
> >> > And nothing else.
> >> There's no problem. Just type in GRASS commands and it should work.
> >> Micha
> >> > What should I do to solve this problem.
> >> > Thank you for your help.
> >> > Kenneth
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> > This mail was received via Mail-SeCure System.
