[Qgis-user] Re: Projection of Shapefile export
Brett Adams badams at spinifexgeophysics.com.au
Tue Oct 5 17:21:20 PDT 2010
  That's unfortunate. Good to know its repeatable.  At least the problem
has been isolated and we know what's required to get it fixed (or so I
think).
Time to find some professional help. I'll keep you informed.
Brett
On 5/10/2010 11:36 AM, Roland Hill wrote:
> Brett,
> I am using Linux and from a previous email I think Ken is as well.
> Yes, it is working on my Linux system.
> I tried installing QGIS onto a Windows 7 system using both the
> Standalone and OsGeo installers. In both cases I couldn't get it to
> work correctly. The standalone installer version placed AGD66 and
> GDA94 versions of my test point 11m apart when it should be more like
> 200m. The OsGeo version just refused to display the AGD66 point.
> I am not sure where to go with it on Windows. I haven't used it for a
> long time. Maybe someone more familiar with the Windows setup can help.
> Cheers,
> Roland
> *ROLAND HILL*
> *Director*
> *Four Winds Technology Pty Ltd*
> *Ph/Fax :  +61 (0)2 6366 9425*
> *Mobile :  +61 (0)41 880 7472*
> *Roland.Hill at fourwindstechnology.com.au
> <mailto:Roland.Hill at fourwindstechnology.com.au>*
> *Privacy and Confidentiality Notice*
> The information contained herein and any attachments are intended
> solely for the named recipients. It may contain privileged
> confidential information. If you are not an intended recipient, please
> delete the message and any attachments then notify the sender of
> miss-delivery. Any use or disclosure of the contents of either is
> unauthorised and may be unlawful. All liability for viruses are
> excluded to the fullest extent permitted by law.
> On 04/10/10 17:06, Brett Adams wrote:
>> Roland / Ken,
>> Sorry to disappear like that. Got called into the dessert for a few days.
>> I tried loading these new files up but can't get them to work. All
>> three projections are now plotting in exactly the same place.
>> Ran a search on the QGIS directory and replaced the AGD84 / AGD66 gsb
>> files with the new ones. Also replaced the srs.db file.
>> I'm assuming you both got this to work. Am I missing a step?
>> Brett
>> On 24/09/2010 7:25 PM, Roland Hill wrote:
>>> Ken / Brett,
>>> The only thing we know for certain is that we are all out of our
>>> depths! Regardless, I think we are on the way to solving this.
>>> Please find a new srs.db here
>>> http://dl.dropbox.com/u/9546967/srs.db. The new file incorporates
>>> both towgs84 parameters and a reference to the distortion files. The
>>> distortion file values appear to take precedence, but I have
>>> included the towgs84 parameters as it looks like the AGD84
>>> distortion files do not cover the states and territories that did
>>> not adopt AGD84. Note that I have changed the AGD66 towgs84
>>> parameters to national ones (previously ACT) according to this
>>> document (page 31) http://www.icsm.gov.au/gda/gdatm/gdav2.3.pdf.
>>> To use the distortion files you need to place these files
>>> http://dl.dropbox.com/u/9546967/agd66.gsb
>>> http://dl.dropbox.com/u/9546967/agd84.gsb in your Proj data
>>> directory (/usr/share/proj on Linux). It is the directory containing
>>> the 'epsg' and 'proj_def.dat' files. Make sure that this is the
>>> directory your Proj installation is actually using by checking the
>>> contents of the PROJ_LIB environment variable (echo $PROJ_LIB). It
>>> may not be set, which is OK. It took me about 4 hours to figure out
>>> I had set it to an old development directory several years ago!
>>> Note that I did try it without the +wktext parameter. It works in
>>> Proj (using cs2cs), but QGIS needs it.
>>> Let me know how it goes on your test points.
>>> Cheers,
>>> Roland
>>> *ROLAND HILL*
>>> *Director*
>>> please delete the message and any attachments then notify the sender
>>> of miss-delivery. Any use or disclosure of the contents of either is
>>> On 24/09/10 07:27, Ken Norris wrote:
>>>> Roland,
>>>> I incorporated your srs.db but the translation falls about 30m short (in
>>>> Melbourne) and about the same distance out at a control point in southern
>>>> Tasmania.
>>>> I see you use the National parameters that '... have an estimated accuracy
>>>> of about 1 metre.' and are most accurate around Canberra (surprise).
>>>> Geoscience recommend use of their distortion tables (xxx.gsb) for more
>>>> accurate work Australia-wide.
>>>> Can you incorporate the parameter reference to the distortion tables in the
>>>> srs.db? I, like Brett, am out of my depth here.
>>>> Regards
>>>> Ken
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Brett Adams
Spinifex Geophysics
0438 861 974
SKYPE:brettadams_spinifex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101006/78dff7c1/attachment.html>
