[Qgis-user] mac owners: please test new html image map plugin: set size of image
Richard Duivenvoorde
rdmailings at duif.net
Wed Oct 6 02:02:02 PDT 2010
Ok, thanks for testing!
if it works flawlessly, I can maybe remove the 'you are using maximized
window'-warning. I had troubles getting this to work 100%, that is the
reason I added the warning when I sense that the window is maximized.
But if it works 100%, even with a maximized window, I will remove the
warning.
again, thanks :-)
Richard
sergio sevillano wrote:
> i have tried the html image plugin
> (in Qgis - osx 10.6.4 intel mac)
> and it seems to work pretty fine
> it always outputs the image at selected set size
> either set or taken from window size.
> in osx there are two Qgis maximized options:
> 1. fullscreen (cmd+f) - work area explodes to fullscreen (no window) that hides main menus and they unhide with a top mouse rollover
> i launch the plugin and gives me 1695x932 size, and same size result image, if i press set button nothing changes.
> 2. maximized (window "+") - that extends the current window to cover all desktop size not hiding the top menu.
> i launch the plugin and gives me 1695x884 size, and same size result image, if i press set button a warning pops up, press ok, and it moves the window a little down left with no change in size nor output image size.
> seems to me that is working ok.
> i dont see why the warning or moving the window,
> maybe thats the error you are looking for...
> sergio
> El 04/10/2010, a las 15:37, Richard Duivenvoorde escribió:
>> Yep,
>> but it is just in the list of python plugins in qgis, search for 'html'.
>> There should be a version 0.5.0 there.
>> Richard
>>> you mean this plugin
>>> http://blog.qgis.org/node/105
>>> El 03/10/2010, a las 19:31, Richard Duivenvoorde escribió:
>>>> Hi,
>>>> Somebody asked the ability to set the exact size of an image to be saved
>>>> with the html image map plugin (or just setting the size of the mapcanvas).
>>>> I've implemented this possibility in the plugin now (v0.5.0), but needed
>>>> some OS-specific offset stuff, and am not able to test it on a mac
>>>> (linux and windows seem ok)
>>>> If users of the plugin which own a mac can have a look, and let me know
>>>> if the size is NOT ok that would be great. Specially the use case where
>>>> you maximized the qgis window before setting a image/mapcanvas size (...
>>>> is this possible on a mac anyway ?).
>>>> Regards,
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
