[Qgis-user] mac owners: please test new html image map plugin: set size of image
sergio sevillano
sergiosevillano.mail at gmail.com
Wed Oct 6 01:34:37 PDT 2010
i have tried the html image plugin
(in Qgis - osx 10.6.4 intel mac)
and it seems to work pretty fine
it always outputs the image at selected set size
either set or taken from window size.
in osx there are two Qgis maximized options:
1. fullscreen (cmd+f) - work area explodes to fullscreen (no window) that hides main menus and they unhide with a top mouse rollover
i launch the plugin and gives me 1695x932 size, and same size result image, if i press set button nothing changes.
2. maximized (window "+") - that extends the current window to cover all desktop size not hiding the top menu.
i launch the plugin and gives me 1695x884 size, and same size result image, if i press set button a warning pops up, press ok, and it moves the window a little down left with no change in size nor output image size.
seems to me that is working ok.
i dont see why the warning or moving the window,
maybe thats the error you are looking for...
sergio
El 04/10/2010, a las 15:37, Richard Duivenvoorde escribió:
> Yep,
> but it is just in the list of python plugins in qgis, search for 'html'.
> There should be a version 0.5.0 there.
> Richard
> sergio sevillano wrote:
>> you mean this plugin
>> http://blog.qgis.org/node/105
>> El 03/10/2010, a las 19:31, Richard Duivenvoorde escribió:
>>> Hi,
>>> Somebody asked the ability to set the exact size of an image to be saved
>>> with the html image map plugin (or just setting the size of the mapcanvas).
>>> I've implemented this possibility in the plugin now (v0.5.0), but needed
>>> some OS-specific offset stuff, and am not able to test it on a mac
>>> (linux and windows seem ok)
>>> If users of the plugin which own a mac can have a look, and let me know
>>> if the size is NOT ok that would be great. Specially the use case where
>>> you maximized the qgis window before setting a image/mapcanvas size (...
>>> is this possible on a mac anyway ?).
>>> Regards,
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
