[Qgis-user] Polygon colours in existing shape files.
Anita Graser
anitagraser at gmx.at
Fri Oct 8 02:45:29 PDT 2010
Hi Ramon,
I guess you'll have to redo the layer style in QGIS. Whatever format Mapinfo uses to store style information (the is no style information contained in any of the shapefile files), QGIS can't interpret it. Depending on the Mapinfo file format, you could propably write a converter to QGIS style files.
Best wishes,
Anita
-------- Original-Nachricht --------
> Datum: Fri, 8 Oct 2010 17:34:57 +0800
> Von: Ramon Andinach <custard at westnet.com.au>
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] Polygon colours in existing shape files.
> Hello,
> I have a number of files that are full of filled polygons, which are
> available as .shp or .tab files. Most of these files represent geological data,
> so the colours of the polygons are an important part of visually
> identifying the data. When I was using these in Mapinfo (and from what I saw in Arc)
> they would come up with the predefined colours consistently.
> When I open these up in Qgis, it does not appear to honour these colours
> (regardless of whether I open the shp or tab file).
> Is there a way to get Qgis to use these colours?
> If there isn't, is there a quicker way of getting these colours back to
> what I'm expecting?
> At the moment the best I can see is to group them by the code fields and
> then redo do hundreds of code colours.
> -ramon._______________________________________________
> Qgis-user mailing list
Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail
