[Qgis-user] How to generate closed polygon from unordered set of points
Micha Silver
micha at arava.co.il
Fri Oct 8 12:56:26 PDT 2010
On 10/08/2010 08:57 PM, John Helly wrote:
> Hi.
> I've got an unordered set of x,y pairs that I would like to plot as a line and then interactively edit the line to make a closed polygon. I've used the points2one plug-in to make an editable line but don't seem to able to join the lines in the correct way by adding/deleting nodes.
> Is it possible to do this with Qgis at all and, if so, how?
Yes, it's certainly possible. What exactly didn't work? Did you enable
snapping? You mention joining lines. Do you need to add line segments so
that everything connects?
Micha
> Thank you.
> Cheers.
> John Helly, UCSD / San Diego Supercomputer Center / Scripps Institution of Oceanography, Climate, Atmospheric Science, and Physical Oceanography / +01 760 840 8660 mobile / stonesteps (Skype) / stonesteps7 (iChat) / /www.sdsc.edu/~hellyj
> Qgis-user mailing list
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
