AW: Re: [Qgis-user] INTERLIS plugin on mac
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Sun Oct 10 09:21:25 PDT 2010
Hi Annina
I think I have a solution. There are two issues:
1) "The PATH problem": You can copy the ili2c.jar to one of the
following directories:
* /usr/bin
* /bin
* /usr/sbin
* /sbin
If you are on your own computer this should not be a problem. You don't
need to do this for the JRE.
2) There is a little bug in the interlis plugin. It needs to know
weather it is a windows machine or not. It uses a python method for this
and counts the word "win" in the OS name returned by the python method.
Since python knows Mac OS X as "Darwin" [1] it will recognize it as a
windows machine.... I cc this email to Marco, the author of the plugin.
@Marco: Can you replace line 63 of interlisdialog.py with "if(osString
== "win32" or osString == "cygwin"):" ?
[1]: http://docs.python.org/library/sys.html
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler at bd.so.ch
http://www.so.ch
> -----Ursprüngliche Nachricht-----
> Von: Annina Hirschi Wyss [mailto:annina.hirschi at gmx.net]
> Gesendet am: Samstag, 9. Oktober 2010 11:46
> An: qgis-user at lists.osgeo.org
> Cc: William Kyngesburye
> Betreff: Re: [Qgis-user] INTERLIS plugin on mac
> Thanks for your help, William,
> I'm quite discouraged... Hope getting some help from the
> plugin developer
> On Oct 8, 2010, at 9:57 PM, William Kyngesburye wrote:
> > On Oct 8, 2010, at 2:33 PM, Annina Hirschi Wyss wrote:
> >> On Oct 8, 2010, at 7:04 PM, William Kyngesburye wrote:
> >>> On Oct 8, 2010, at 11:32 AM, Annina Hirschi Wyss wrote:
> >>>> Hi List,
> >>>> I can't get the INTERLIS plugin to work on my OSX
> 10.6.4, QGIS 1.5.0 (Framework install from KyngChaos). It
> says it can't find the JRE, so I set the JAVA_HOME variable
> and path, but no change...
> >>>> Am I missing something, or did someone make similar experiences?
> >>> Do you need model support?  From what the dialog says for
> loading Interlis data, Java is needed for model support,
> implying that will still read interlis data without it.
> >> Yes I'd like to. but even if i try to load an interlis xml
> without a model, it's not selectable in the "choose"-window
> > I don't know about this, it sounds like a problem with the
> operation of the plugin.
> >>> Adding the JRE path to the environment is yet another
> case where OS X applications do not get any of the shell
> environment (ie set in your .bash_profile).  There is a
> hidden, little documented (if at all) method to get
> environment into an application, but I don't like to
> encourage it because it's clunky to use (hidden file, and no
> GUI unless you install 3rd party software).
> >> do you mean the /etc/paths-file? Or is it more complex?
> > That's also just for the shell.
> > If you really, really, really want to use this hidden
> environment thing, install the RCEnvironment preference pane.
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > "We are at war with them. Neither in hatred nor revenge and
> with no particular pleasure I shall kill every ___ I can
> until the war is over. That is my duty."
> > "Don't you even hate 'em?"
> > "What good would it do if I did? If all the many millions
> of people of the allied nations devoted an entire year
> exclusively to hating the ____ it wouldn't kill one ___ nor
> shorten the war one day."
> > <Ha, ha> "And it might give 'em all stomach ulcers."
> > - Tarzan, on war
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101010/acdc1e0e/attachment.html>
