AW: Re: [Qgis-user] INTERLIS plugin on mac
William Kyngesburye woklist at kyngchaos.com
Sun Oct 10 09:48:00 PDT 2010
On Oct 10, 2010, at 11:21 AM, Ziegler Stefan wrote:
> Hi Annina
> I think I have a solution. There are two issues:
> 1) "The PATH problem": You can copy the ili2c.jar to one of the following directories:
> * /usr/bin
> * /bin
> * /usr/sbin
> * /sbin
> If you are on your own computer this should not be a problem. You don't need to do this for the JRE.
Remember that this is a workaround only.  I recommend leaving the system directories alone (especially /bin & /sbin!) and using that RCEnvironment prefpane to setup the Java paths (also really a workaround, until we can get a general Qgis environment configuration feature).
Also, it's not the path to the plugin java code that's the problem (the plugin should take care of that) - it can't find the JRE.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
