AW: Re: AW: Re: [Qgis-user] INTERLIS plugin on mac
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Sun Oct 10 10:03:58 PDT 2010
> Remember that this is a workaround only. I recommend leaving
> the system directories alone (especially /bin & /sbin!) and
> using that RCEnvironment prefpane to setup the Java paths
> (also really a workaround, until we can get a general Qgis
> environment configuration feature).
Yes. Definitely not the best solution ever :-)
> Also, it's not the path to the plugin java code that's the
> problem (the plugin should take care of that) - it can't find the JRE.
As far as I understand this is only because of the bug in the qgis
plugin. I'm not sitting on my mac now but I guess qgis finds the JRE in
/usr/bin/java. Without the bug, model support is still not enabled
because of the missing ili2c.jar.
regards
Stefan
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101010/ea6e22a1/attachment.html>
