AW: Re: AW: Re: [Qgis-user] INTERLIS plugin on mac
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Tue Oct 12 00:28:32 PDT 2010
Hi Annina
> Just a queston: It seems only INTERLIS 1 is supported?
> Are there plans to support INTERLIS 2 too?
As for ogr2ogr INTERLIS 2 is supported [1]. A quick look into the plugin
code shows that the first problem is the file chooser which allows you
to select only *.itf files. I changed this to *.xml and *.xtf. I can now
select also INTERLIS 2 files but after hitting the ok button qgis
crashes... I then tried to open the INTERLIS 2 file as a normal vector
layer (with the default vector layer dialog). This kills qgis too and
you would have no model support (but is it necessary for INTERLIS 2
since it doesn't have to polygonize the geometries). Last attempt with
the console:
ogr2ogr -f "ESRI Shapefile" shp2/
Test23_erweitert.xml,Test23_erweitert.ili
This is just another frustration:
Info: Folder /usr/local/bin/standard doesn't exist; ignored
Speicherzugriffsfehler
Without the model it works and creates all the shapes. I don't know if
the crashes are due to our installation. Does it work for you? I'm not
sure if I ever used INTERLIS 2 before. But I'm sure it should work.
Perhaps Pirmin (ogr2ogr interlis driver guru) can give you more
information.
[1]: http://www.gdal.org/ogr/drv_ili.html
regards
Stefan
> Thanks again!
> Annina
> On Oct 11, 2010, at 8:45 AM, Marco Hugentobler wrote:
> > Hi Stefan
> > Thanks for looking into this. The changed plugin (v. 0.6.1)
> is uploaded to the
> > repo.
> >> Since python knows Mac OS X as "Darwin" [1] it will
> recognize it as a
> >> windows machine....
> > Oh, true. I thought it would be something with 'mac' in it.
> But that would be
> > like saying GNU instead of Linux :-)
> > Regards,
> > Marco
> > Am Sonntag, 10. Oktober 2010, um 18.21:25 schrieb Ziegler Stefan:
> >> Hi Annina
> >> I think I have a solution. There are two issues:
> >> 1) "The PATH problem": You can copy the ili2c.jar to one of the
> >> following directories:
> >> * /usr/bin
> >> * /bin
> >> * /usr/sbin
> >> * /sbin
> >> If you are on your own computer this should not be a
> problem. You don't
> >> need to do this for the JRE.
> >> 2) There is a little bug in the interlis plugin. It needs to know
> >> weather it is a windows machine or not. It uses a python
> method for this
> >> and counts the word "win" in the OS name returned by the
> python method.
> recognize it as a
> >> windows machine.... I cc this email to Marco, the author
> of the plugin.
> >> @Marco: Can you replace line 63 of interlisdialog.py with
> "if(osString
> >> == "win32" or osString == "cygwin"):" ?
> >> [1]: http://docs.python.org/library/sys.html
> >> regards
> >> Stefan
> >> Mit freundlichem Gruss
> >> Stefan Ziegler
> >> Leiter Aufsicht
> >> Kanton Solothurn
> >> Bau- und Justizdepartement
> >> Amt für Geoinformation
> >> Rötistrasse 4
> >> 4501 Solothurn
> >> Telefon 032 627 75 96
> >> Telefax 032 627 75 98
> >> stefan.ziegler at bd.so.ch
> >> http://www.so.ch
> >>> -----Ursprüngliche Nachricht-----
> >>> Von: Annina Hirschi Wyss [mailto:annina.hirschi at gmx.net]
> >>> Gesendet am: Samstag, 9. Oktober 2010 11:46
> >>> An: qgis-user at lists.osgeo.org
> >>> Cc: William Kyngesburye
> >>> Betreff: Re: [Qgis-user] INTERLIS plugin on mac
> >>> Thanks for your help, William,
> >>> I'm quite discouraged... Hope getting some help from the
> >>> plugin developer
> >>> On Oct 8, 2010, at 9:57 PM, William Kyngesburye wrote:
> >>>> On Oct 8, 2010, at 2:33 PM, Annina Hirschi Wyss wrote:
> >>>>> On Oct 8, 2010, at 7:04 PM, William Kyngesburye wrote:
> >>>>>> On Oct 8, 2010, at 11:32 AM, Annina Hirschi Wyss wrote:
> >>>>>>> Hi List,
> >>>>>>> I can't get the INTERLIS plugin to work on my OSX
> >>> 10.6.4, QGIS 1.5.0 (Framework install from KyngChaos). It
> >>> says it can't find the JRE, so I set the JAVA_HOME variable
> >>> and path, but no change...
> >>>>>>> Am I missing something, or did someone make similar
> experiences?
> >>>>>> Do you need model support? From what the dialog says for
> >>> loading Interlis data, Java is needed for model support,
> >>> implying that will still read interlis data without it.
> >>>>> Yes I'd like to. but even if i try to load an interlis xml
> >>> without a model, it's not selectable in the "choose"-window
> >>>> I don't know about this, it sounds like a problem with the
> >>> operation of the plugin.
> >>>>>> Adding the JRE path to the environment is yet another
> >>> case where OS X applications do not get any of the shell
> >>> environment (ie set in your .bash_profile). There is a
> >>> hidden, little documented (if at all) method to get
> >>> environment into an application, but I don't like to
> >>> encourage it because it's clunky to use (hidden file, and no
> >>> GUI unless you install 3rd party software).
> >>>>> do you mean the /etc/paths-file? Or is it more complex?
> >>>> That's also just for the shell.
> >>>> If you really, really, really want to use this hidden
> >>> environment thing, install the RCEnvironment preference pane.
> >>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> >>>> http://www.kyngchaos.com/
> >>>> "We are at war with them. Neither in hatred nor revenge and
> >>> with no particular pleasure I shall kill every ___ I can
> >>> until the war is over. That is my duty."
> >>>> "Don't you even hate 'em?"
> >>>> "What good would it do if I did? If all the many millions
> >>> of people of the allied nations devoted an entire year
> >>> exclusively to hating the ____ it wouldn't kill one ___ nor
> >>> shorten the war one day."
> >>>> <Ha, ha> "And it might give 'em all stomach ulcers."
> >>>> - Tarzan, on war
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Dr. Marco Hugentobler
> > Sourcepole - Linux & Open Source Solutions
> > Webereistrasse 66, 8134 Adliswil, Switzerland
> > marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> > Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101012/eb7d716a/attachment.html>
