[Qgis-user] INTERLIS plugin on mac
Annina Hirschi Wyss
annina.hirschi at gmx.net
Sat Oct 16 04:11:46 PDT 2010
Hi Stefan,
Thanks for your investigations!
On Oct 12, 2010, at 9:28 AM, Ziegler Stefan wrote:
> Hi Annina
> > Just a queston: It seems only INTERLIS 1 is supported?
> > Are there plans to support INTERLIS 2 too?
> As for ogr2ogr INTERLIS 2 is supported [1]. A quick look into the plugin code shows that the first problem is the file chooser which allows you to select only *.itf files. I changed this to *.xml and *.xtf. I can now select also INTERLIS 2 files but after hitting the ok button qgis crashes... I then tried to open the INTERLIS 2 file as a normal vector layer (with the default vector layer dialog). This kills qgis too and you would have no model support (but is it necessary for INTERLIS 2 since it doesn't have to polygonize the geometries).
Same thing here
> Last attempt with the console:
> ogr2ogr -f "ESRI Shapefile" shp2/ Test23_erweitert.xml,Test23_erweitert.ili
> This is just another frustration:
> Info: Folder /usr/local/bin/standard doesn't exist; ignored
> Speicherzugriffsfehler
Same thing here
> Without the model it works and creates all the shapes.
For me this gives the "Segmentation fault" but this time without the "Info: Folder..."
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101016/9969db55/attachment.html>
