AW: Re: [Qgis-user] INTERLIS plugin on mac
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Sun Oct 17 23:41:03 PDT 2010
Hi Annina
do you have some Interlis 2.2 data? I think the ogr driver was written
when 2.2 was the offical Interlis 2 version. But that's just
guessing....
regards
Stefan
-----Ursprüngliche Nachricht-----
Von: Annina Hirschi Wyss [mailto:annina.hirschi at gmx.net]
Gesendet am: Samstag, 16. Oktober 2010 13:12
An: Ziegler Stefan
Cc: qgis-user
Betreff: Re: [Qgis-user] INTERLIS plugin on mac
Hi Stefan,
Thanks for your investigations!
On Oct 12, 2010, at 9:28 AM, Ziegler Stefan wrote:
Hi Annina
> Just a queston: It seems only INTERLIS 1 is supported?
> Are there plans to support INTERLIS 2 too?
As for ogr2ogr INTERLIS 2 is supported [1]. A quick look into the
plugin code shows that the first problem is the file chooser which
allows you to select only *.itf files. I changed this to *.xml and
*.xtf. I can now select also INTERLIS 2 files but after hitting
the ok button qgis crashes... I then tried to open the INTERLIS 2
file as a normal vector layer (with the default vector layer
dialog). This kills qgis too and you would have no model support
(but is it necessary for INTERLIS 2 since it doesn't have to
polygonize the geometries).
Same thing here
Last attempt with the console:
ogr2ogr -f "ESRI Shapefile" shp2/
Test23_erweitert.xml,Test23_erweitert.ili
This is just another frustration:
Info: Folder /usr/local/bin/standard doesn't exist; ignored
Speicherzugriffsfehler
Same thing here
Without the model it works and creates all the shapes.
For me this gives the "Segmentation fault" but this time without the
"Info: Folder..."
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101018/e4fbec64/attachment.html>
