[Qgis-user] Color Scale Bar does not find the colour table or QML file
Agustin Lobo
alobolistas at gmail.com
Tue Oct 12 11:29:08 PDT 2010
Hi!
I've tried to use the plugin Color Scale Bar under ubuntu 9.04 (qgis
1.5 from binaries). While
this plugin works fine under windows XP, under ubuntu I've found:
1. It would seem that the plugin requires a *.tbl or *.qml file for
the "Open a colour table or QML file" dialog, yet the file created by
"1-band raster colour table" is a *.txt file
2. If you select the file created by "1-band raster clour table", a
second dialog prompts for the file again. If you cancel this second
dialog the file initially selected appears in the general Dialog of
the plugin, but when you click "Create" an error message is displayed:
"You have to first select file".
3. Same behaviour for *.qml files
I've filled a ticket, wish to tell tha author as well but he/she is
not mentioned in the doc of the plugin.
Thanks
Agus
